We've taken Permalac Original & made it even better!
Introducing Permalac NT
Permalac NT Clear Coat is a Direct-to-Metal ultra-low VOC Clear Coat
that meets the rigorous performance requirements of the Green Seal standards
Available in a Semi-Gloss, Satin, Matte & Ultra-Flat Finishes, our Matte finish has a LEED v4 Qualified certificate Green Seal and LEED v4 Qualified
Permalac NT Matte is LEED v4 Qualified for indoor emissions, meets California Department of Public Health 1.2 indoor emissions, is LBC Red List 3.1 Compliant & is also FDA Food Contact qualified.
Permalac Original built a reputation on exceptional performance.
When it came time to deliver a cleaner Permalac, we made sure we still deliver that same level of exceptional performance.
You will find Permalac NT is cleaner, harder and more scratch resistant. The Green Seal set a high bar for lacquer performance and we are pleased that our new Permalac NT is up to the test.
Green Seal Requirements for Metal Lacquer
- Permalac Reputation for exceptional long lasting rust and tarnish protection
- Lowest VOC in the industry
- Direct to Metal application for ease of use
- No fading, no blistering, no peeling, 10 yr. warranty
- Salt and Chemical Resistance
- Crystal Clear protection that allows the beauty of the metal to shine through
- Meets Green Seal and LEED standards and CA regulations for low VOC and performance.
Applications and Users
- Metal Artwork, Ornamental Metal Work
- Metal Roofing, copper, steel, aluminum
- UV Protection for Exterior Doors, Railings
- Interior metal surfaces, brass, copper, steel aluminum
- Metal Stairs, Architectural Steel, Aluminum
Permalac NT is formulated to be sprayed. It does not need thinners added to it.
Here's our new video about "How to Apply Permalac":
https://www.youtube.com/watch?v=mdUgv7uOrmk
Permalac is also available in several transparent colors to go over light colored steel or metal: NT Blackener (Black), NT Brass (Yellow Brass), NT Bronze (Dark Browns), NT Christmas Gold (Deep Gold), NT Rose Gold (Reddish Gold) & also in 2 opaque colors: NT Black & NT Copper.
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
