Permalac Flattening Wax is a pre-dispersed flattening paste that is compatible with all Permalac products. Add 2 to 10 ounces of Permalac Flattening Wax to 1 gallon of Permalac to achieve your desired level of flattening. 1-quart package.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
SDS
