DEVELOPED FOR PROFESSIONALS 4-IN-ONE ACTION - Cleans, polishes, restores, and protects 38 surfaces... brass, copper, stainless steel, silver, gold, chrome, fibreglass, ceramics, glass, acrylics, painted surfaces and much more. BEST VALUE FOR MONEY - The easiest and most economical product to use... No spills, residue, odour, cloth saturation or mess. USED ON COUNTLESS ITEMS - The most universal product available... Use on silverware, bar taps, faucets, chandeliers, counter tops, sinks, mirrors, porcelain, and much more.   LONG-LASTING INGREDIENTS - Removes oxidation, heat discolouration, corrosion, scale... Leaves an anti-oxidant protective barrier.
 Demanded by those who have tried it
good
first time use did the job
Works well on stainless steel sinks!
I used some Peek polish on a stainless steel sink with great results. Did an excellent job of removing hard water stains and dish rings. It's not going to make your stainless into a mirror, but it'll clean it up and make it look shiny and newer, so long as you put the elbow grease into it. For a real good first-pass, use some 000 or 0000 steel wool and this polish to help you get the hard water spots off. Once it's cleaned well and you're satisfied, feel free to hit it again once a month or so to keep it nice and shiny. Do not use this on coated surfaces, but go to town on raw stainless steel. Work the polish with the grain of the stainless (assuming it's brushed stainless like 90% of kitchen sinks). If you use this on chrome, use a light touch. It doesn't take much - let the polish do the work for you. Hard scrubbing will lead to scratching and hazing.
