The "Starter kit" contains everything you need to start making single and double-sided PCB's in just a few minutes... transfer paper, copper laminate and sealing foils.
< Click the image here to see the entire product "wrapper".
The only other items you'll need are a bowl of water, paper towel, etchant of your choice and a small can of Acetone to remove the toner and foil "resist" image from the board after etching.
With this Starter kit and the recommended "TIA" applicator (GBC laminator) you will have the ability to make high density, high quality single and double-sided PCB's first time, every time in just a few minutes... plus you can do it without using an etching tank too! (See TECH SUPPORT > No Etching Tank!)
The "Starter kit" includes the following items:
Toner Transfer Paper:
10-sheet pack
2 packs in kit
8-1/2" x 11"
Resealable bags
Can NOT Damage Any Laser Printer or Photo-Copier!
Toner Reative Foils:
Seals the toner
Size: 8" x 15 feet
2 packages
Green - etching
White - silkscreen
Copper Clad Boards:
1x & 2x Copper
1/2oz Copper
.032" thick
Size: 8" x 10"
2 panels/pack
4 panels total
Also included in the "Starter Kit" is a special custom printed set of circuit test images printed on a sheet of Toner Transfer Paper. It is a built-in trouble-shooting tool if your images aren't transferring properly. It's used as a guide to compare to the quality of the printouts from your laser printer or copier.
- Single & Double Sided PCB's
- Board size up to 8"x10"
- Quick 8~10min fabrication
- PCB's made "ON DEMAND!"
- Trace pitch down to .006" (!)
- Money back guarantee
- 1-yr laminator warranty
- Customer support in the USA
Mini Mass-Production
Make as many as you need No wait times
Ideal for prototyping Alterations easily made
