null
Permalac Lacquers
PERMALAC is a crystal clear, durable, air-dry coating clear coat that protects all exposed steel & metal from corrosion from the effects of UV, salt water air, wind, sand, sun, acid rain, dog urines, etc. It will protect exposed metal from corrosion for up to 8 years for indoor metals & 5 years for outdoor metals. It is a DTM (direct-to-metal) clear coat and functions equally well if used over or under other coatings. Its proven reliability has been tested in countless field applications from special architectural finishes, to automotive (or motorcycle) trim, to marine hardware, lighting fixtures, bronze sculptures, to stainless steel signage...
PERMALAC always achieves superior results.
All PERMALAC LACQUERS HAVE A COVERAGE RATE OF APPROX 400 SQ FT PER GALLON
  • Permalac Black Acrylic Paste Additive - 1 Quart
    Permalac Black Acrylic Paste Additive This black acrylic paste additive can be used to yield a solid black finish if you wish to tint the Permalac yourself. To obtain an opaque black effect, add approximately 1 oz of black paste for every 8 fluid ounces...
    $138.00
    Add to Cart
  • Permalac Flattening Agent - 1 Pound
    Peacock Flattening Agent is a matting powder that is compatible with all Permalac products. Add Peacock Flattening Agent to 1 gallon of Permalac to achieve your desired level of flattening. Recommended Mix: Semi-gloss: add 100 grams to one...
    $73.60
    Add to Cart
  • Permalac Flattening Wax - 1 Quart
    Permalac Flattening Wax is a pre-dispersed flattening paste that is compatible with all Permalac products. Add 2 to 10 ounces of Permalac Flattening Wax to 1 gallon of Permalac to achieve your desired level of flattening. 1-quart package.
    $117.30
    Add to Cart
  • Permalac Low VOC Thinner
    Low VOC Thinner is a medium speed lacquer thinner formulated with VOC-exempt solvents. Designed for use with Permalac EF or Permalac NT. Use when the ambient temperature is 55°F to 88°F. When spraying, thin between 20-50%. If the Permalac is...
    $50.60
    Choose Options
  • Permalac NT - Ultra-Low VOC Clearcoat
    We've taken Permalac Original & made it even better!  Introducing Permalac NT Permalac NT Clear Coat is a Direct-to-Metal ultra-low VOC Clear Coat that meets the rigorous performance requirements of the Green Seal standards...
    $47.15
    Choose Options
  • Permalac NT Copper Matte
    Permalac NT Copper Matte is available in either 1 quart cans or a 4 quart bundle. This color is good to go over roofs & such to make them look like copper or match other copper items while protecting the metal surface. It is only available in Matte...
    $88.55
    Choose Options
  • Permalac NT Low Odor Thinner
    NT Low Odor Thinner This is a VOC-exempt thinner best used with the Permalac NT. Use when the ambient temperature is 55°F to 88°F. When spraying, thin between 20-50%. If the Permalac is drying too quickly, and you notice blush or any other...
    $42.55
    Choose Options
  • Permalac NT Opaque Black
    Permalac NT Black is a fast-drying, easy-to-apply acrylic lacquer coating. It is an opaque tinted, low VOC formula which lays down similar to a paint. Permalac NT Black is highly resistant to environmental breakdown caused by UV, acid rain, and salt. ...
    $97.75
    Choose Options
  • Permalac Retarding Thinner
    Retarding Thinner can be added to the Permalac Original, Permalac EF, or Permalac NT. It should be used to extend flow time and prevent solvent blush when working in high temperatures or high relative dew points. This will make Permalac take around an...
    $42.55
    Choose Options
  • Permalac Standard Hot/Cold Thinner
    Standard Hot/Cold Thinner is a regular speed lacquer thinner. Use when the ambient temperature is 50°F to 65°F. Thin Permalac Original, EF 20% when spraying. No thinner will be needed for brushing unless you notice brush strokes or irregularities.
    $32.20
    Choose Options
  • Permalac Strip Thinner
    Permalac Strip Thinner consists of a blend of solvents designed to dissolve and remove cured Permalac Original, Permalac EF, Permalac NT, and Permalac SR from metal surfaces without marring the substrate. This material is composed of VOC-exempt...
    $34.50
    Choose Options
  • Permalac Transparent Colored Lacquers
    We have added some transparent/translucent colors to our Permalac line that are meant to be applied over light colored steel or metal for special effects. These products still offer the 5/8 years of protection against corrosion on all steel & metals...
    $88.55
    Choose Options
