These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
works
First off I'm very new to anodizing, this dye did give a nice rich color, but not exactly orange in my opinion. More of a rich golden color really, not exactly what I was looking for but a quality product non the less.
Great Color
I tried the other oranges first and was quite disappointed. Disappointed to the point that orange was not a color we would offer. I had better luck using copper and letting the part take as much color as it could to come up with an orange that I was ok with. Then I tried Orange 2B and was very impressed. Orange is back in our color offerings.
