Caswell Olive Drab Chromate will impart an heavy, non-iridescent olive drab green coating over zinc or cadmium deposits. The finish also serves as an excellent base for paint.
MIXING:
DO NOT USE OLIVE DRAB CHROMATE AT FULL STRENGTH. DO NOT PRE-MIX PART I AND PART II. A VIOLENT REACTION MAY OCCUR.
- In a plastic tank (HDPE preferred) add 2 US Gallons of distilled water.
- Add 8 fl oz Olive Drab Part I and mix with a plastic mixer
- Add 8 fl oz Olive Drab Part II and mix with a plastic mixer
Solution is now ready for use. Use at 70-90 deg F. If heating use Stainless Steel heaters (No Titanium) Air agitation recommended but not required.
OPERATION:
- Zinc or cadmium plate the part
- Rinse with distilled water
- Dip in a 5% solution of muriatic or hydrochloric acid for 5 secs (not required but recommended)
- Dip in Olive Drab Chromate for 15-60 seconds
- Dry with warm air not exceeding 160 deg F.
TROUBLESHOOTING:
| Problem | Cause | Solution | |||
| Dull streaks/bare spots | Poor rinsing after plating or chromating
Chromate is too strong | Increase rinsing. Add air agitation to rinse water. Dilute chromate |
| Bronze to reddish color | Temperature is too high Concentration of chromate is too high Concentration of Olive Drab II too low | Lower chromate Dilute chromate Add Olive Drab II |
| Olive color too iridescent | High pH | Lower pH |
| Dull powdery film; loose and non-adherent | Rinse or dryer too hot | Adjust temperature to 120°F (50°C) or less |
| Poor corrosion resistance | Temperature of dryer over 160°F (71°C); dehydrates the film pH too high | Reduce temperature
Lower pH |
Hazardous Shipping Info
GHS Info
SDS
