These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
4 Reviews Hide Reviews Show Reviews
It's not as dark as the screen makes you think, which is a good thing!!!
It's not really black like the color swatch on caswell's site makes you think. It is a great drab green. We do this at an hour and 8 minutes 12 volt c-voltage. When you look at it at first it doesn't look like olive it looks more brown, but splash it and compare and there is no question! good stuff. just play around with the times.
Good products
Good products and fast shipping
Thanks for the prompt service
EXCELLENT seller which is why I continue to buy from!!!
Takes very fast
To get a good looking olive color I was mixing it with the Green AEN.
