The next best thing to a sand blaster! Lasts up to 10 times the life of a wire wheel! Will not puncture skin Does not shed bristles - unlike dangerous wire wheels Will not rust and maintains its shape
Ideal for:
Scratch brushing aluminum and other metals for decorative finishes
Removes paint, corrosion, weld scale, rust & weld marks from steel
Gently removes paint and varnish from wood.
Sands wooden moldings, railings, turnings and banisters
Removes cement from tiles, stone and brick mortar
Prepares fiberglass, rubber, and all plastics for adhesive application
Frosts glass
3€ wheels - ideal for use with a small hand drill.
3 Reviews Hide Reviews Show Reviews
We used this to brush titanium welds
wear and wear and wear. no flying bristles
I took a piece of a wire brush out of my tongue once and that will never happen with this nylon since they hold and won't fly off in deadly little arrows
Very good product
Very good for preping aluminum for polishing. Removes any medium ding for an excellent result. I now use this product instead of metal wheels.
