Nickel Plating Accessory Package
The Accessory Package Contains:
- 2 x Copper Pipes (6"L x 1/2" dia)
- 2 X Aluminum Strips (6"L x 1" dia)
- Connecting lead set to connect the power supply to the plating tank
- Safety glasses and rubber gloves
- 6' of bare copper wire (to hang items into the tank)
- 1 Quart Zincate (to pretreat the aluminum practice pieces)
- pH tester and calibration kit
- Aluminum Polishing Kit (to polish the practice pieces). You need an electric drill to use this kit.
- 3" diam Nylon Bristle Brush
