Includes a 3 Gal Nickel Plating Kit and a 3 Gal Flash Copper Plating Kit.
Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before nickel plating.
3 Gallon Kit:
- 3 x 3.5 Gal Plating Tanks & Lid
- 2 x 6" x 8" Nickel Anodes and Bandages
- 2 Packs Nickel Crystals with Brightener (Makes 3 Gals)
- 2 x Copper Anodes 4" x 8" and bandages
- Flash Copper™ Part A - 4 Quarts
- Flash Copper™ Part B - 1 Quart
- Flash Copper™ Part C - 1 Quart
- 1 Pack SP Degreaser (Makes 4 Gals)
- 2 x Pump Filter/Agitators
- The Caswell Plating Manual
- Free Technical Support
                Recommended Skill Level
                    Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
  			 SDS
                Combo KitI was very satisfied with the service and shipping.
