Nickel/Copy Chrome™ Brightener 1 Quart Treats 6 Gal
SDS
I have been using your brightener for over ten years
I use Caswell Nickel brightener for Nickel plating firearms in Livingston, TX I find that it produces superior appearance and bright Nickel plating compared to other brighteners I have tried. They did not have the brilliance that the Caswell product produced.
