Includes a 4.5 Gal Nickel Plating Kit and a 4.5 Gallon Chrome Plating Kit.
This combo kit is ideal for chrome plating parts that do not require a copper strike, such as polished steel. It's also useful if you already have a copper plating system, enabling you to Triple Chrome Plate your parts.
4.5 Gallon Kit:
- 3 x 6 Gal Plating Tanks & Lid
- 2 x 6" x 8" Nickel Anodes and Bandages
- 3 Packs Nickel Crystals with Brightener (Makes 4.5 Gals)
- 2 x 12" x 12" Chrome Anodes
- 3 Cans Chrome Crystals (Makes 4.5 Gals)
- Chrome Activator
- Mist Control Balls
- 2 Packs SP Degreaser (Makes 8 Gals)
- 1 x Pump Filter/Agitator
- The Caswell Plating Manual
- Free Technical Support
Not available to residents of California unless an appropriate permit has been obtained. Use REPROCHROME® instead.
Recommended Skill Level
Advanced level products require multiple steps to achieve end results, such as conductive paints, or multiple cleaning steps. While many novice customers have used these products successfully in the past, we recommend some experience using easier processes before trying an advanced level product.
Hazardous Shipping Info
GHS Info
SDS
