Includes a 4.5 Gal Nickel Plating Kit and a 4.5 Gal Acid Copper Plating Kit.
Useful to put a heavy layer of copper plating over non-ferrous metals (copper, brass, bronze, zincated aluminum), then polish and nickel plate.
4.5 Gallon Kit Contains:
- 3 x 6 Gal Plating Tanks & Lid
- 2 x 6" x 8" Nickel Anodes and Bandages
- 3 Packs Nickel Crystals with Brightener (Makes 4.5 Gals)
- 2 x Copper Anodes 4" x 8" and bandages
- 3 Packs Copper Crystals (Makes 4.5 Gals)
- 3 x 1.5oz Copper Brightener A
- 1 x 4oz Copper Brightener Part B
- 2 Packs SP Degreaser (Makes 8 Gals)
- 2 x Pump Filter/Agitators
- The Caswell Plating Manual
- Free Technical Support
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
SDS
