Includes a 15 Gal Nickel Plating Kit and a 15 Gal Acid Copper Plating Kit.
Useful to put a heavy layer of copper plating over non-ferrous metals (copper, brass, bronze, zincated aluminum), then polish and nickel plate.
15 Gallon Kit Contains:
- 3 x 20 Gal Plating Tanks & Lids (12W x 24L x 18H)
 - 2 x 18" x 20" Nickel Anodes and Bandages
 - 10 Packs Nickel Crystals with brighteners (Makes 15 Gals)
 - 2 x Copper Anodes 18" x 20" and bandages
 - 10 Packs Copper Crystals (Makes 15 Gals)
 - 10 x 1.5oz Copper Brightener A
 - 3 x 4oz Copper Brightener Part B
 - 4 Packs SP Degreaser (makes 16 Gals)
 - 2 x Pump Filter/Agitators
 - The Caswell Plating Manual
 - Free Technical Support
                Recommended Skill Level
                    Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
SDS
4 Reviews Hide Reviews Show Reviews
nice kit
I use this on my job site highly recommended great kit...
me and my son love it
Great kit highly recommend,
nice kit to start with
Comes with everything you need am very happy with this kit...
great kit
Highly recommended, looks great and was easy to use can't go wrong
