Complete Super Casting Kit & Mini Super Casting Kit
Mini Super Kit Includes:
- AB28 Kit 8oz Super Plastic Alumilite Regular
- 1/4 lb. QuickSet RTV Silicone Rubber
- 1/4 lb. Alumilite Synthetic Modeling Clay
- 1 oz. Measuring Cups
- Stir Sticks
- How-To Booklet
The Super Casting Kit contains everything you need to make a mold and cast your part in 1 day! All measuring tools are included for the Alumilite and the QuickSet Rubber. All products are non-toxic and can easily be used in your home. The Mini Super Casting Kit contains all of the same materials as the Super Kit includes but in smaller quantities. (note: the Mini Super Casting Kit does not contain Mold Release Powder)
