Mack-Norris Trickster
(Actual Overall Length 7")
The Trickster is a striper with a handle length of 4-1/4". Jim Norris helped design this brush and with his sign painting background likes the longer length of a brush handle. For the stripers that prefer a shorter handle the modification is quick and easy. The striper is made of pure blue squirrel hair and has a length out of 2-1/4". The long length of the hair allows the brush to carry a good load of paint for a long distance. You can stand the brush up on the tip to create super fine lines even with the larger sizes.
Available In Sizes 7/32" (00), 1/4" (0) and 5/16" (1)
