Liquid Fiberglass Boat Cleaner
Easily removes dirt, film, oxidation, oil, grease, rust and exhaust stains from fiberglass finishes. Restores the original color quickly without hard rubbing or buffing. Leaves a chemically clean surface to which Collinite waxes can bond perfectly. Increases long-lasting brilliance and performance of protective wax coating.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
