COLLINITE LEATHER & VINYL TREATMENT
Leather And Vinyl Treatment
Cleans, beautifies and protects leather and vinyl automotive, marine, aircraft and household upholstery in a single, easy operation. Leaves a high gloss, protective coating against wear, deterioration, spills and oxidation. Can be easily cleaned with a damp cloth.
