| PROD | Style | Width In Inches | Length In Inches | Indiv. Price |
| BALLFB | Ball | 0.75 | 0.75 | $2.96 |
| CYFBMD | Cylinder | 1 | 1.25 | $2.96 |
| CYFB11 | Cylinder | 1 | 1 | $2.96 |
| CYFBL125 | Cylinder | 1.25 | 1 | $2.96 |
| BUFBMD275 | Bullet | 0.75 | 1.5 | $2.96 |
| CONEFB | Cone | 0.75 | 1 | $2.96 |
| CYFB1X15 | Cylinder | 1 | 1.5 | $2.96 |
| DOMEFB | Dome | 1 | 1 | $2.96 |
| BALLNFB | Balloon | 0.75 | 1 | $2.96 |
| BUFBLG395 | Bullet | 1 | 2 | $3.85 |
| CYFBL2 | Cylinder | 1 | 2 | $3.85 |
| CYFBL34 | Cylinder | 0.75 | 1.5 | $2.96 |
