Perfect For Spraying Our Ceramic Coatings
HVLP stands for High Volume, Low Pressure. HVLP guns operate at 10 PSI at the nozzle cap, transfer 70% paint on the surface being coated. This gun gives little overspray and provides a very fine silky smooth atomized process. Requires a 2.5HP or larger compressor for peak performance.
Specifications:
- Gravity Fed
- 1.5mm Nozzle
- 600cc cup capacity (20 fl oz)
- Air Inlet: 1/4" NPS
- Air Hose: 3/8" NPS
- Air Consumption: 6.8 CFM
- Recommended Air Pressure: 29 PSI
- Weight: 1.4 lbs
Kit Contains:
- HVLP Gun
- 600 cc Aluminum Cup
- 1.3mm Nozzle
- 1.3mm Needle
- 1.8mm Nozzle
- 1.8mm Needle
- Air Cap
- Plastic Grip Brush
- Spanner
- Witch Brush
- Case
