HOURGLASS BUFFING WHEEL
The hourglass buff™ fits straight into a drill chuck. The unique shape allows the buff to rest on a tailpipe without spinning off. By simply rotating the drill, all angles of the pipe can be buffed rapidly. The tapered end allows you to get into difficult corners.
