Heavy Duty Paste Fleetwax
RATED #1 WAX BY PRACTICAL SAILOR
POWERBOAT REPORT - Editor's Choice. For Marine & Aeronautical Finishes. Developed especially to seal and shield against acid rain, sun, salt spray, bugs and other environmental acids. Easily applied and non-abrasive, wax will prevent finish deterioration and the adhesion of foreign elements.
