COLLINITE HEAVY DUTY LIQ FLEETWAX 1/2 GL
Heavy Duty Liquid Fleetwax
Cleans, protects and beautifies marine finishes in one easy operation. No hard rubbing or buffing. Contains rare, pure Carnauba waxes combined with advanced polymer technology. Leaves double coating of protection that lasts & lasts. Out performs products costing many times more.
