Mix 1 kg can with 5.5 US Pints Distilled Water, and 1 fl oz of Battery Acid. Plate at 2 amps per square inch.
Not available to residents of California unless an appropriate permit has been obtained
Hazardous Shipping Info
GHS Info
SDS
