Handheld Drill Buffing Kit
Kit Includes:
- 1 x Black Compound
- 1 x Brown Compound
- 1 x White Compound
- 1 x Green Compound
- 1 x Red Compound
- 1 x Blue Compound
- 1 x 4" Sisal Wheel
- 2 x 4" Spiral Sewn Cotton Wheels
- 2 x 4" Loose Cotton Wheels
- 2 x 4" Canton Flannel Wheels
- 1 x Arbor Adapter
- 1 x Cartridge Roll Kit
- 1 x Assorted Felt Bob Kit (1/8" shaft)
- Buffing and Polishing Booklet
This kit will polish any metal or plastic part, and is designed to be used with a regular electric drill. It includes compounds and wheels to polish all types of metal and plastic. The included buffing booklet details the steps involved for each different type of metal.
The included arbor adapter allows the buffing wheels to be mounted in the chuck of the drill, and allows for quick wheel changes. The Cartridge Roll kit includes a mandrel, which is mounted in the drill chuck, and three tapered and three cylinder sanding rolls, course, medium and fine. These quickly remove casting marks and deep scratches.
The included felt bob kit can be used with the buffing compound to give access to tight spaces on parts.
If you plan on polishing with a drill, this is the only kit you'll need.
5 Reviews Hide Reviews Show Reviews
Great way to start
The items I needed were high quality and were all included except a rake, so I used a wire brush I had. I used up the sisal and sewn cotton wheels right away, so it would have been better to have more of them instead of the large bars of emery which I will not use in a lifetime--especially the red and blue. It would be nice to have a choice for beginners. --
The kit seems fine
Good product
Good quality product
Good products and fast shipping
Great on a budget
Excellent tool for those who don't need/want a designated buffing motor, or want a portable unit
Fast and good!
Fast and good what more can i say!
