These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
			 SDS
                Great utilitarian colorGrey NLN is the kind of color that blends well with other decor and nearly a full 60% of our product is in this color.
                Nice colorThis is a very nice gray color with brow/smokey undertones. If you leave it too long, it will make your part look black. Careful timing is required to get matching parts across different lots. It's tricky but produces a very interesting color.
