These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
Great gun metal blue
I recently took on the challenge of at home anodizing. Caswell was the best place for reliable information, I even used there online chat help. This dye was perfect for what I wanted to do. My goal was a deep blue for firearm parts and it took excellently. I would recommend to a friend and just know when your dying the depth of the color is up to you. I made a deep blue piece and a lighter glossy grey. depending on how much time it soaked.
I like it.
Nice grey color with some blue hue.
