These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
5 Reviews Hide Reviews Show Reviews
Beautiful Color
I used this green dye at 140° on a part with a .7 mil oxide film. The uptake of dye was very fast and uniform. My dye time was about 4 minutes. The color was a Sublime Green. This dye is fantastic!
Very cool green
Comes out as a forest green, very nice green
Sharp
Very good bright "Zombie" color.
darker then shown
for me when I use this color its almost a Forrest green
I like it!
It's a good true green. Takes to the ano well, the different shades are great to play with! I will be having a lot of fun with this product.
