Graphite Conductive Paint - 4 fl oz
Add a Conductive Layer Onto Plastics and Other Items
Makes Electroplating Onto Non Metal Parts Easy
Safe Water Based Acrylic Formula
Graphite is highly conductive and this new formula allows for easier coverage and avoids losing fine details in the part. Apply 1-2 coats by brush and allow to dry. Can be thinned with water.
Perfect for all plastics, wood, leather and organic parts (leaves etc). For organics, we recommend applying a lacquer based paint and allowing to dry first.
Large 4 fluid ounce bottle will cover approx 5-10 sq ft.
After paint has dried, apply acid copper or nickel by brush plating or tank plating.
GHS Info
SDS
