These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
5 Reviews Hide Reviews Show Reviews
Bright, noticable color
Read the description rather than the printed color on the website, it is a bright orange with hints of gold. Can't be ignored!
Good depth
This color really has some good depth to it depending on the angle you are looking from and light angle.
great color
This is another fine Caswell product
Thanks for the prompt service
EXCELLENT seller which is why I continue to buy from!!!
More on the orange side
More just orange than "Golden". Still a very good color that I found easy to use, just not quite what I expected.
