Glare Turbo Action Wheel Cleaner is the most powerful, effective, and fastest working wheel cleaner on the market. Safe for ALL types of wheels - Aluminum, Chrome, Magnesium - as well as clear coated and painted wheels. Makes your wheels look show room bright and shiny the easy and safe way. Removes and dissolves dirt, grime, brake dust, and grease. Just spray on Glare Turbo Action Wheel Cleaner to dirty wheels and hose off with clean water to get your wheels looking like new again!![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
