Overall Dimensions: 66" (h) x 43" (w) x 62" (d)
Working Dimensions: 30" (h) x 39" (w) x 40" (d)
Side Door: 18" x 28"
Window: 25" x 10"
Construction: 16 gauge steel
Gun Assembly: Foot operated: 14 CFM @ 90-100 PSI
Electrical: 110 Volts
Dust Collector: DC1500
Weight: 345 lbs. (common carrier)
