These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
8 Reviews Hide Reviews Show Reviews
Amazing
Works well, love the color
Excellent
Expensive, but it`s worth it.
Super bright hot pink
Very deep in color, can be bubble gun as well magenta with a little dip in purple.
Great color
This is really a great color. My wife is going to love it!
bright
Great color turns out very similar to color swatch shown. I use color at room temp.
Bright
color came out great.... the pink was deeper and richer than I thought it was going to be
good colour.
Good colour. My girls love the colour.
good colour.
