FLITZ WAXX PROTECTANT 32OZ
WAXX PROTECTANT Flitz Waxx Protectant is a white carnauba and beeswax formula that provides exceptional results on all painted surfaces, clearcoat, gelcoat, lacquer, polyurethane, Fiberglass®, Plexiglas®, Eisenglass®, acrylics, plastics and much more. Available in two sizes.
