FLITZ INSTANT CAL LIME RUST REMOVER 16OZ
Patented, revolutionary, X-strength GEL quickly and easily removes even the crustiest of stains, deposits and build-up. Leaves a water-repellant shield. GEL formula has proven more effective than the competitive products!
