FLITZ SPEED WAX 16OZ
SPEED WAX Flitz Wäxx / Speed Wax is a Premium Brazilian Carnauba based formula that simply sprays-on, wipes-off and fills in swirls and hairline scratches. Water-based. No streak. No smear. No white residue. Environmentally friendly.
