FLITZ FAUCET & FIXTURE WAX 7.6oz
FAUCET & FIXTURE WAX Flitz Faucet and Fixture Wax is a white carnauba and beeswax formula that provides exceptional results on lacquer, clearcoat, gold plating, powder-coat, polyurethane, acrylics, faucets, door locks, kick plates, outdoor lighting fixtures, Fiberglass®, showers, tubs, vanities, granite, marble, cultured marble, Corian®, and all solid surfaces. Excellent protection from tarnish on Gold Plated Items.
WOW
Works as described, jewelry has a great shine
The right product
This product work just perfectly because it is not strong to damage the surface of the item that you worked on it.
