Fine Point Detailing Wand
Perfect for detailing small areas
The Fine Point Detailing Wand makes it easy to apply plating to small areas while allowing me to keep the plating away from where I DON'T want it to go. Perfect for two-tone plating.
Needed for you Plug'n plate
Great for silver plating the smallest areas.
