FastGold
24ct and 18ct Gold Brush Plating Solutions
FastGOLD is a new highly concentrated brush plating solution, designed especially for use with all types of brush plating machines, including pen platers.
FastGOLD contains over 1 pennyweight of gold per 4oz of solution, (2 troy oz per gallon) which enables the solution to plate an even layer of gold as quickly, if not more quickly, than any cyanide based product.
FastGOLD plates quickly even in cold weather less than one minute for most articles!
FastGOLD deposits over nickel, sterling silver, silver plate, gold, rhodium, and most other similar metals. Copper alloys and steel should be flash plated with nickel prior to gold plating.
FastGOLD evenness of color is easy to control, thanks to special brighteners which help provide excellent coverage and leveling ability.
![]() | FastGOLD is the longest lasting and most durable gold money can buy! FastGOLD is more reflective than ordinary gold, because it applies to the substrate in flat €˜platelets€™ rather than in the granular structure of cyanide plating solutions. |
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
GHS Info
SDS
3 Reviews Hide Reviews Show Reviews
works great
It plated great looks awesome well worth its money
bright fast finish
works great to get bright 24k finish
Great Plating Solution!
I give this plating solution 4 out of 5 stars due to the price being so high. Yes, I know the price of gold continues to rise but around $100 per ounce I just don't see the point in purchasing more of the plating solution unless you're profiting on it. I give the solution itself 5 stars due to the quality and evenness of color. The plating is a rich gold color, not watery looking (like the regular, cheaper gold solution) like many other plating solution. It takes a LOT of effort to make it wear and normally you'd have to buff it off to remove it. I gold plated a key for my car with this stuff a few years back and used the key day in and day out to open, start, and lock the car. After 6 months of use (I sold the car) the gold plating on the key (aside from where the teeth of the key scrape inside the ignition cylinder) looked like the day I plated it! Very good plating solution but for the $ I'd shop around for a smaller quantity of some other solutions to try and if nothing is as durable as this one then I could see spending ~$400 for 4oz!
