SHAFT EXTENDER 3/4" BORE RIGHT HAND
Designed especially for larger buffing & polishing units.
The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces.
Slides onto 3/4" diameter shaft and tightens with two grub screws.
Great for mounting larger sized wheels. 6-1/2" Long. Threaded section is 2" long. Fits 1/2" Wheel Holes
3 Reviews Hide Reviews Show Reviews
great
fits perfect on my baldor buffer/grinder
good
nice
Great product
A nice little product, well machined and very sturdy.
