SHAFT EXTENDER 3/4" BORE LEFT HAND
Designed especially for larger buffing & polishing units.
The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces.
Slides onto 3/4" diameter shaft and tightens with two grub screws.
Great for mounting larger sized wheels. 6-1/2" Long. Threaded section is 2" long. Fits 1/2" Wheel Holes
great
very well made
Extra Long Shaft Adpater 3/4" Bore Left Hand
I was making a buffing station for my knives and I needed a 3/4" bore shaft adapter. Ordered the left hand model first to check out the quality. Excellent product. Exactly what I needed. Will be ordering the right hand model now along with some rouge and more cotton wheels.
