PERMANENTLY MARKS ANYTHING METAL...IN SECONDS!
ETCHES MARK INTO SURFACE €” ETCH-O-MATIC will Etch into the surface of Anything made of Metal, including Tools, Instruments, Equipment or Manufactured Parts, anything that can be Typed, Written, Drawn or Photo Processed on a Special Stencil. This includes Names, Numbers, Designs, Logos, Trademarks or even Your Own Signature. Using an Electro Chemical principle, the New ETCH-O-MATIC can Etch as Deep as .003" of an Inch in Less than 30 Seconds or Mark the Hardest Tool Steel and Carbides almost Instantly. It marks any Flat or Round Metal Surface down to 1/16" Diameter and any Metal Thickness from Thin Foil up to the Largest Castings easily. Most Marks (which look like Printing or Engraving) take about 3 to 20 Seconds (the Longer Dwell Times are for Deep Etching) and are Permanently Etched into the Tool or Manufactured Part.
FAST AND VERY EASY TO USE!
ETCH-O-MATIC is FAST and EASY TO USE. Anyone in Your Organization can become an EXPERT in JUST MINUTES and produce Professional Looking Marks Quickly. In Fact, Etch-O-Matic is by Far the Very Easiest Marking System to Learn that is Available Today! Also, You will find that ETCH-O-MATIC is not only the Fastest way to make Permanent Marks on Anything Metal, but is by Far the LEAST EXPENSIVE method on the Market Today. Your Marks will Cost just Fractions of a Cent to Produce and You will be Extremely Pleased with the Result.
COMPARES WITH LASER MARKS
Most Marks will Compare Favorably with Laser Marks on Metal and are Easier and Sometimes Even Faster to Make. In Fact You have Seen Marks made by Etch-O-Matic hundreds of times before but probably did Not Realize it since the Marks are Used so often in Commerce Today. If you have ever seen a Feeler Gauge, Drill Bit, Milling Cutter, Saw Blade, Knife Blade, Ball Bearing Race, Carbide Cutter or Thousands of other types of Metal Tools, Parts, Instruments or Equipment then You have probably seen Marks made by Etch-O-Matic. In fact, we have Marks in a good Percentage of all of the Cars, Trucks, Commercial and Military Aircraft, Submarines, Hospital Surgical Instruments and Implant Devices and we even have Marks in the Nose Cone of the Space Shuttle. (Yes, NASA called and said that they used an Etch-O-Matic to Mark an Inspection Date and Number in the Nose Cone of the Space Shuttles.)
ETCH-O-MATIC STARTER KIT
Lowest Priced Kit available Anywhere, Yet it Does the Job in Industry, in Plants, Machine Shops and Everywhere Metal Marking is needed. The Marker Unit is 10 volts, 2 amps and is Excellent for Light Duty Marking of Tools and Parts. (Transformer is inside marker unit)
KIT CONTAINS: ETCH-O-MATIC marker with standard head marking size 7/8" x 13/4", electrical cord, ground plate, 2 oz. Electrolyte solution in plastic bottle, 10 special stencils, neutralizer, deep etching adapter clip and complete instructions. Each kit will make approximately 1,000 marks before refill supplies are needed..
