null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • PUMP SILVERING KIT
    PUMP SILVERING KIT
    Prepares Non-Conductive Parts (Plastic, Glass, Ceramic, Leather, Baby Shoes, Leaves, Flowers etc) for electroplating Make larger non-conductive parts conductive, ready for electroplating with the Caswell Pump Silvering Kit. Ideal for spraying parts of...
    $603.90
    Add to Cart
  • RECTIFIER - 12V/500A - 220V 3 PHASE
    500 Amp Rectifier DC Output: 500 amperes 0-12 volts AC Input; 3 phase either 220 volt or 440 volt Cooling: air cooled Control: manual powerstat Metering: analog dc ammeter and voltmeter Ripple: 5% or less at any setting Cabinet: approx 31" high, 25"...
    $10,740.00
    Add to Cart
  • RECTIFIER - 250 AMP
    RECTIFIER - 250 AMP
    250 Amp Rectifier DC Output: 250 amperes 0-12 volts AC Input: 110 volt 1 phase 60 hz Cooling: air Control: manual powerstat Ripple: 5% or less at any setting Metering: analog dc ammeter and voltmeter Cabinet: plastic approx 16" high x 27" wide x 18"...
    $6,609.00
    Add to Cart
  • RECTIFIER - 30 AMP
    RECTIFIER - 30 AMP
    30 Amp Plater This heavy duty unit will plate larger items. Will nickel & copper plate items up to 3 sq ft in area.  Not suitable for anodizing, due to it's lack of constant current mode. 0 - 20 Volts d.c. 0 - 30 Amps d.c. Continuously variable...
    $349.00
    Add to Cart
  • RECTIFIER 0-30A, 0-32V
    30 Amp, 32V Constant Current Rectifier Best for anodizing. 32V allows for increased current densities and shorter anodize times Please note, during the current supply chain crisis, we may substitute this item for a similar item that WILL perform as well...
    $499.00
    Add to Cart
  • REPROCHROME Upgrade Plating Kit - 4.5 Gal
    The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Buy This Kit If You Already Have a Nickel Plating Kit, or wish to convert from Triple Chrome to Reprochrome® Introducing REPROCHROME®, a unique Cobalt/Tungsten...
    $446.59
    Add to Cart
  • REPROCHROME® Triple Chrome Plating Kit - 1.5 Gal
    The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Introducing REPROCHROME®, a unique Cobalt/Tungsten alloy that contains no chrome, nickel or toxic materials. REPROCHROME® duplicates a chrome plate in color,...
    $845.89
    Add to Cart
  • REPROCHROME® Triple Chrome Plating Kit - 3 Gal
    $1,136.29
    Add to Cart
