DuraBlue Nitre Aerosol Kit
Spray On Nitre Bluing
Get The Sought-After Look of Nitre Bluing
Also known as Fire Blue, Nitre Bluing was historically seen on small parts of handguns and long guns. The brilliant blue finish can be used on any type of metal using the convenienct aerosol can.
DuraBlue Nitre Aerosol Kit Contains:
- One DuraBlue Nitre Aerosol Can
- One 6oz Trustrip Cleaner/Degreaser
- One Scrubbing Pad
