Dome Point Detailing Wand
3 Reviews Hide Reviews Show Reviews
Dome point detailing wand
Dome Point Detailing wand allows for small and accurate plating of metal components.
Perfect for detailing small areas
The Dome Point Detailing Wand makes it easy to apply plating to small areas while allowing me to keep the plating away from where I DON'T want it to go. Perfect for two-tone plating.
Needed for you Plug'n plate
Great for silver plating smaller areas.
