Mix this bag with 1.5 Gals of Distilled Water. Add 16 fl oz brightener.
Refer to plating manual for plating instructions.
GHS Info
			 SDS
                Easy and it works.I purchased this product to make more solution for a job I had to do chrome plating two pistols for a friend. Ive used the copy chrome brush plate kit but needed more for a bath process so I could get all the nooks and crannies. With a little inventing on my own with some home made stainless anodes, and some brass cathode hangers to suspend the items in the 2 gallon bucket I set up, I made these two guns look like a pro done plating job. With one hour of use for each part I have sucessfully chrome plated both receivers and slides within one day and the results supprised me. I will definately be using more of this stuff.
