Copy Chrome™ Kit
Improved More Complete Kit - New, Bigger Sizes
Looks Like Chrome
Hard Like Chrome - Tougher Than Nickel!
Keeps Its Shine - Just Like Chrome!
No Dangerous Chemicals - No Fumes - No Corrosive Acids
One coat system - eliminates 2 steps!
Tanks are rectangular (12W x 24L x 18H)
NEW!  IMPROVED PERFORMANCE KIT
Larger Anodes – give more plating, with more even results
Plates up to 60 sq ft of Copy Chrome™
Constant auto agitation and filtering with New Pump/filter included
Simpler Instructions
Copy Chrome™ is a SIMPLE plating kit that provides almost all the benefits of chromium plate - without all the hassle! The entire plating process takes the same time as our regular nickel plating kit, 15 minutes for indoors decorative, 30 minutes for tools, 1 hour for tough outside jobs!
The Copy Chrome™ process is ideal for all your small items such as door handles, brackets, hinges, nuts & bolts, stamped steel covers, etc. It can be applied to:- steel, copper, brass, bronze, old nickel plate, and with the aid of Zincate Primer, aluminum.
All instructions and operating procedures are detailed in the Caswell Plating Manual. Each anode will plate about 32 sq. ft of surface area at 0.0005" before it needs to be replaced. The solution is virtually permanent. No waste chemicals or dangerous fumes are produced.
15 Gallon Kit Contains:
- 2 x 20 Gal Plating Tank & Lids (12W x 24L x 18H)
 - 2 x 12" x 18" Anodes and Bandages
 - 4 Packs SP Degreaser (Makes 16 Gal)
 - 10 Packs Copy Chrome™ Crystals with brighteners (Makes 15 Gal)
 - 1 x Pump Filter/Agitator (extra agitation may be required)
 - The Caswell Plating Manual
 - Free Technical Support
                Recommended Skill Level
                    Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
GHS Info
SDS
