Includes a 15 Gal Copy Chrome Plating Kit and a 15 Gal Acid Copper Plating Kit.
Useful to put a heavy layer of copper plating over non-ferrous metals (copper, brass, bronze, zincated aluminum), then polish and Copy Chrome plate.
15 Gallon Kit Contains:
- 3 x 20 Gal Plating Tanks & Lids (12W x 24L x 18H)
- 2 x 18" x 20" Copy Chrome Anodes and Bandages
- 10 Packs Copy Chrome Crystals with brighteners (Makes 15 Gals)
- 2 x Copper Anodes 18" x 20" and bandages
- 10 Packs Copper Crystals (Makes 15 Gals)
- 10 x 1.5oz Copper Brightener A
- 3 x 4oz Copper Brightener Part B
- 8 Packs SP Degreaser (makes 16 Gals)
- 2 x Pump Filter/Agitators
- The Caswell Plating Manual
- Free Technical Support
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
GHS Info
SDS
