Mix 13 ounces of part A with 36 ounces of Copy Cad/Zinc Part B and 1.5 gallons of distilled water. Refer To Manual For Complete Instructions.
GHS Info
SDS
Mirror like finish when used with brightener!
The versatility and results are amazing. I will be ordering again!
Simply the best
Caswell deals in good quality plating equipment
